Old Jun 27, 2014 | 11:38 PM
  #712 (permalink)
pizzaguy
Default Re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
So dremmel through the tumbler?
NO. Read the tutorial, you are drilling the pin out so you can remove the assembly from the column.
Do i still need to remove the pins?
You drill out the one pin that is holding it in the column.
Also how do i remove the wire harness from the back?
As I recall, you simply pull the connector off the back - I think I used pliers but it yanks off.
I am planning to order the new ignition switch and tumbler and suggestions where to buy and what part number works best?
I have no idea, in my expericence, there is no need to buy expensive lock parts. The only place I know of would be a CHrysler dealer.
I just want to throw it out there I have 167K on my XFire!!!!!and counting!!
You did good to get that far without this happening earlier. Mine started to fail at 44000 miles and I fixed it without drilling - but again, I got to it before it locked up completely; by simply following the tutorial in post #1.
