Old Aug 3, 2014 | 11:56 PM
xxx_fire's Avatar
xxx_fire
Default Re: UPDATE!!! On car won't start after running out of fuel🚫
Originally Posted by oledoc2u
Could be simple as a fuel filter, or as bad as a fuel pump if you are sure it is fuel related. Crankshaft Position Sensors going bad, can be the problem as well. Hard starting, rough idle, etc...
Where is the fuel filter located? And do you know if the xfire comes with an external fuel pump or is it in the gas tank?
