UPDATE!!! On car won't start after running out of fuel🚫
Old Aug 3, 2014 | 10:13 PM
xxx_fire's Avatar
Default UPDATE!!! On car won't start after running out of fuel🚫
So I let my car sit for a week, then it started right up this morning. I drove it for about 30 min then let it sit for 3 hrs. Came back to my car it almost didn't want to start but it did. I let it sit and idle for about 10 min then the car turned off. I tried to turn it back on after that but it just kept cranking again and would not start as usual. Does this help to narrow down the problem??
Old Aug 3, 2014 | 10:35 PM
Default Re: UPDATE!!! On car won't start after running out of fuel🚫
Could be simple as a fuel filter, or as bad as a fuel pump if you are sure it is fuel related. Crankshaft Position Sensors going bad, can be the problem as well. Hard starting, rough idle, etc...
Old Aug 3, 2014 | 11:56 PM
xxx_fire's Avatar
Where is the fuel filter located? And do you know if the xfire comes with an external fuel pump or is it in the gas tank?
Old Aug 4, 2014 | 12:17 AM
tighed1's Avatar
Under the car (external). There's a cover protecting it that you gotta remove to access it.
Fuel pump relay is in the Relay Control Module BTW.
foxy1305
U.K.
Jan 1, 2020 11:41 AM
smmanley1996
Sep 4, 2015 04:40 PM
Keepmeinmind13
Jul 10, 2015 01:05 AM
ultrajim49
17
Jun 27, 2015 12:20 AM
carmax
Jun 18, 2015 01:30 PM
