No............. The RCM (relay control module) is easily resoldered. MOst issues are broken solder connections where the connector pins solder to the board. SOMETIMES a relay will go bad, but they are cheap online (about $5 each with shipping if you order 5 at a time).
The CPS (crank position sensor) goes bad when hot quite often, the car will start and run until the CPS gets too warm. Easy to change, $45 online.
https://www.germanautosupply.com/sto...sensor-86.html I carried a spare for three years before mine went out - but several of us carry spares - they do go bad quite often.
Sometimes the OTHER CPS (cam position sensor) will fail but it's really kinda rare.
