Thread: oil or?
Old Nov 21, 2014 | 09:59 PM
amx1397
Default Re: oil or?
Originally Posted by Speedy4x4
Got to Walmart the 5 qt mobile 1 0w40 synthetic is around $25 and a good filter $17.
The cheap crap not even in the right viscosity is around $15 a jug and $5 for cheapest filter.
So every 7600 miles in reccomended oil you will spend $67.
And 7500 miles worth of cheap crap $87.50 changed every 3000 miles.
Plus you would be using a viscosity that was not designed for our engines, or have the additives that is needed for the aluminum engines with the alusil coated cylinders.
We are all about finding better or saving money but bad oil is not how to do it and will coat ALOT more in the long run.
First thing I did when I bought my ssb was change fluids in everything so I knew what was in it and when it was changed.
Speedy4x4 you forgot ,,to replace the engine at a cost of between $2500.00 tp $5000.00
