Old Jan 2, 2015 | 04:12 PM
  #730 (permalink)
Mrmiata's Avatar
Mrmiata
Default Re: Minnesota X-fires
Don't guess I could talk you into dropping a key in the mail huh? Replaced my fob with a case from online.. The key itself attaches with a roll pin to the "round" steel part.. which on my key seems to be off on it's machining as it doesn't lay flat when closed - even when in the OEM case. The "replacement fob case" had a narrower key at the attachment end than standard crossfire key.. as I found out when trying to swap it in.
