GregWork
1, How does this new radio pull out, any special tools needed?
A1: comes with its own removal tools.
2, When you switch the red and yellow wires in positions A7 and A4 do you release them from the socket with a paper clip, or what is the best tool to use for this?
A2: there is a simple protruding small spike on the pin that needs pushed back to release. You can pull the wire out without release, but then have to bend the spike back into place to hold the wire in the socket.
3, The after market frame mentioned (Insert metal aftermarket frame into DIN slot), is that the part that comes with the radio?
A3: yes comes with the radio.
Just as a reference - the sleeve locking tabs "matched up" to be able to push them out and secure?
