Old Jan 27, 2015 | 06:44 PM
  #782 (permalink)
eatmycrackers's Avatar
eatmycrackers
Default Re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
Originally Posted by eatmycrackers
Well the transponder is plugged in correctly and does not look damaged so is it possible it is just not lined up correctly? The guide says to have the wire end on the same side as the flat part of the key tumbler. When I go to start the car there is an engagement of an immediate kill switch to the car. Key fob is able to lock and unlock doors, so it must be a transponder issue not transmitter or key itself
I lined the transponder up correctly according to the guide and still no luck. Any other suggestions?
