Old Feb 15, 2015 | 03:22 PM
massanu's Avatar
massanu
Default Re: Double Din Project: Disassembling question
I can probably help with #2 : remove the battery and battery tray, you will see a pass-thru grommet that you can use.
as to #1, some have said that centered behind the tag is a hole that is sometimes covered with painted metallic tape.
Hey thanks for your messahe
Just a question about this "pass-thru"
DO you know where its ending ? I mean will I need to unmount a lot of interior part to get the cable back from the pass-thru ?
Thanks man, I appreciate
