Old Mar 3, 2015 | 02:11 AM
  #45 (permalink)
syfi's Avatar
syfi
Default Re: DIY Rear Cambers
Originally Posted by wvwonder
Great thread, my problem is the front camber, my front camber is -2.4 left and -3.6 right . That's over 2.1 away from spec. Will the Fronts only require the install of the eccentric alignment bolts. .Will the aftermarket/OEM eccentric bolts that allow +/-1.5 degree adjustment be close enough to spec. Using part number :2023300118.
I know the K-Mac would give more but that's more than I would like to spend. I
Just want tread life and safety
Thank you for any help you can give me.
The adjustment bolts should be fine. You'll need 2 for each side - 4 ea. total.
Mercedes-Benz Suspension Eccentric Bolt Kit 2023300118 - Febi 07752 - Free Shipping
Also here.....
http://www.autohausaz.com/search/pro...ber=2023300118
