Old Mar 17, 2015 | 11:40 AM
  #792 (permalink)
syfi's Avatar
syfi
Default Re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
Originally Posted by sparklesknox
I am new to the forum and just got my crossfire, but already have problems with the key not wanting to turn, so far has not locked up completely. I have the pdf just want to make sure that the spring and pin that you remove at the end of the pdf are the parts that are causing this issue? And I don't need to buy any new parts if I follow the pdf instructions? I don't want to mess it up and have to pay to have it fixed.
The pin & spring are what is removed to solve the problem. No new parts needed. If taken to the dealer for fix they will charge you $300 to replace the switch which will eventually have the same problem later on. Removing the pin & spring is a permanent fix and doesn't affect any steering lock. The fix has been well tested by many members and is totally safe. Has been done on both of my XFs.
