Old May 29, 2015 | 07:34 PM
  #851 (permalink)
onehundred80
Default Re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
Originally Posted by crymar
If the '07s had modified ignition lock units installed at the factory, isn't there a possibility that an ignition lock unit bought from a dealer in 2014 may have come from the batch used for the 2007 production run?
If the part was modified then the part number should indicate that change, the part number would originally be XXXXXXXAA and the modified part would be XXXXXXXAB etc.
If you ask for the original part you may get it but you should be told that part is obsolete and replaced by the newer numbered part, I say should be.
