Old May 30, 2015 | 12:35 PM
KDW4Him's Avatar
KDW4Him
Default Re: '04 coupe electrical problems
Originally Posted by chturner
Okay I think putting the old chip and board into the new key would work, but I am hesitant to try because the old fob is the only reason my car will start right now and I don't want to screw it up. Advice?
Wouldn't the new key, just the metal part, moved to the old FOB do the same? We are trying to get you to match the new ign. cylinder/key combo to the chip in the original FOB. The chip in the FOB mates with the ring antenna and coding in the car. Side note, it sounds like your door key and ignition key are different now, beware!
When it comes to the fuel door lock don't think remote unlock. From a diagnostic point of view if the FOB remotely unlocks the car the remote and receiver are fine go to the one item that is failed, the fuel door mechanism to investigate.
Dome light has a switch on it, set it to come on when the doors are opened.
