Old May 31, 2015 | 12:33 PM
Mrmiata's Avatar
Mrmiata
Default Re: Body Control Module and Wiper problems
Originally Posted by bourbonton
Hello
Roadster 2005
If I fit a replacement Body Control Module does it have to be re programmed to my specific car.
My wipers will only stop when ignition is off, any ideas
Many thanks
My 2 cents may not be worth that..
I had swapped BCM with my wife's car into my coupe ( checking lighting in hers). When I turned the ignition on in my coupe the wipers started up - non stop - till ignition was turned off. Seems I didn't fully get the wire harness seated.
As far as programming.. I was told "lucky" I didn't try to start the car.. (programming thing)
AND
I've read somewhere along the way that approximately 20 seconds of ignition on is required for this.
Not much help but do dig into the BCM programming as best as you can.
