Old Jun 24, 2015 | 04:29 PM
  #861 (permalink)
breakneck's Avatar
breakneck
Default Re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
Originally Posted by NeedInfo
We removed the assembly to take out the pin and spring ......but can not figure out how to get the assembly back in. Can someone please help us.
The assembly fits into the assembly housing (the bracket that holds the assembly) at an angle. You'll need to put the assembly into that bracket with the key facing more toward a 70-90 degree angle with the dash - the assembly slides into the housing at that angle, then you twist it down, counter-clockwise, so that the keyhole is facing as it normally would. That locks the assembly in place. This is how I remember doing it, anyway, as I remember the assembly had to be twisted clockwise to remove it. Hope this helps.
