Old Jun 24, 2015 | 04:32 PM
  #862 (permalink)
breakneck's Avatar
breakneck
Default Re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
Originally Posted by Istrix
I'm having this issue as well. My key will not turn into the 1 position, and my steering wheel locked up from my efforts. Thanks to everyone that's posted guides, pics, and fix info.
I've got all my panels removed, and I've drilled a healthy chunk out of the (*******) locking pin. It is still there, however it's now around midnight and I think my neighbors would like to stop listening to the sweet sounds of my drill. I've got it to the point that I can turn the key enough to release the wheel lock, but I still can't get the key into the 1 spot. Any thoughts on that? Is it perhaps that I simply haven't eliminated the pin completely yet? I can't work on it right now so the only thing I have to do right now is stress over it.
You probably haven't drilled the pin out far enough to remove the assembly. Keep drilling that pin until you can pull the assembly out and remove the spring and pin from the assembly. After that the key will move freely.
