Old Jul 29, 2015 | 09:46 PM
  #882 (permalink)
KDW4Him's Avatar
KDW4Him
Default Re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
Originally Posted by cameronscott
I removed the spring and pin and the reinstalled the little metal door. While I had the assembly out I purchased a new switch (202 545 01 04). I installed the new switch and reinstalled the assembly.
1. Now that I think about it, I did not have the black retaining ring (the one with the black wire) installed. It was hanging off to the side. Could this have been the issue?
What new switch specifically? I have done two of these and never needed parts.
The ring is the antenna for the SKREEM module. It must be able to "read" the chip inside thew FOB. If not, no start. Or more precisely probably 2-3 almost starts or runs then dies right away.
