Red Paul
Not knowing anything about cars...it sounded like it was coming from behind the dash. (behind the radio area) I found myself turning right (of the ignition) to listen to the whine sound. Would a mechanic shop check these lines for leaks?
MrMiata....I did a copy and paste of what you said about tire well area. Should I have spouse check that out when this evening??
thanks,
Sandy
I was hoping someone else might have some valid input here on the trunk module. As far as a leak in the lines.. trust me you will hear it.. and there are none under the dash.
The majority of locking - unlocking issues arise from this module.. the FACT it will unlock doors means those keys are synced to the car. The actual dash button working does throw a kink in the works though.
