Old Sep 14, 2015 | 07:11 AM
ala_xfire
Default Re: Oil neck removal? (Picture)
Originally Posted by toob
You have to remove the whole oil breather cover to get to a screw inside. Once removed it becomes obvious, one cross-head screw on the inside to release pressure then a quarter turn of the whole neck to remove.
Not entirely true. While it can be done this way, it is easier to insert a thin strong screwdriver between the valve cover and the catch extension on the filler neck, then rotate.
