Oil neck removal? (Picture)
Got it off! Found a thread on benzworld via google on a different car, but with similar breather covers. He used a wooden down on the underside and hammered to remove the breather covers. I made my own makeshift dowel that I had to modify with a box knife. It worked!
Now to get these puppies powdercoated!
Here are pictures of the access holes with the breather cover removed:
^ Passenger
Driver
Got the neck off on the valve cover. Now the oil cap will fit directly on top. I noticed there is no rubber o-ring on the cap. Is one needed since I am placing directly on the valve cover now?
^ Passenger
Driver
The seal on the extension is the same size anyway.
So, after getting the crossover tweaked manifolds from Needswings, I checked in with this thread and appreciate the pictures 180! After carefully looking at the pics and then the interface between the breather cover and the filler extension, it seemed clear that the filler neck stops were designed to just "ride" over the mounting stops on the engine. So, I got a pair of large channel locks, put a bit of cloth in the jaws to avoid scratching the filler neck, and gently but firmly rotated the filler neck counterclockwise. Came off like a champ!! easy peasy. Replaced the leaky oil filler cap gasket, and then put the cap directly on the breather cover. No more leak :-)
This was my experience. Your mileage may vary LOL.
LE Cross
Oct 17, 2016 06:35 AM
skeet370
Jul 18, 2015 01:02 PM
