Old Sep 18, 2015 | 08:07 PM
onehundred80
Default Re: Oil neck removal? (Picture)
Originally Posted by 4drturbo
Got it off! Found a thread on benzworld via google on a different car, but with similar breather covers. He used a wooden down on the underside and hammered to remove the breather covers. I made my own makeshift dowel that I had to modify with a box knife. It worked!
Now to get these puppies powdercoated!
Here are pictures of the access holes with the breather cover removed:
^ Passenger
Driver
Got the neck off on the valve cover. Now the oil cap will fit directly on top. I noticed there is no rubber o-ring on the cap. Is one needed since I am placing directly on the valve cover now?
The gasket seal is under flush and may not appear to be there, it is though, just poke it gently to feel the rubber.
The seal on the extension is the same size anyway.
