Re: A lot of Water droplets visible inside headlight lens
unsc005
Thanks again onehundred80. I read the link and this should be a big help.
If you take the headlight out you may as well rinse the interior with methanol as outlined in a post here by Maxichon. If you do not want to take it out you can remove the two headlight bulbs ans use a hair dryer eo blow warm air through the headlight.
Next you have to find the cause of the water getting in there in the first place. This can be a leak in the seal somewhere or it needs the special kit fitted to stop humid air getting into the light.
