A lot of Water droplets visible inside headlight lens
on
Re: A lot of Water droplets visible inside headlight lens
The bottom picture shows what it should look like. It is one half of the kit required to rid the lens of the condensation problem.
The top picture shows you are missing the two caps and the rubber lens cover that should have that very fine mesh window on the back of it.
Correct. Right now I have only the 2 original larger caps and the 2 vents that were factory installed broke off which was probably the major cause of the issue but no one prior to me getting it addressed the problem. I need to get the kit that has the 2 plugs and the mesh cap but I know those are not available any longer. Are there any other solutions to this issue aside from that?
The mesh needs to be a hydrophobic mesh, it allows air to pass through which allows for the pressure inside and outside to equalize.
The size of the holes in the mesh restrict water, the size we need has to restrict mist.
Once the correct mesh has been decided on a hole can be cut in the headlight cap and a piece of mesh attached to it with no gaps in the joint. Obviously the mesh has to be very fine.
mike28117
08-16-2015 10:32 AM
