Old Nov 24, 2015 | 07:33 PM
  #53 (permalink)
csteve0355's Avatar
csteve0355
Default Re: Auto Dimming Mirror - it's not just for '04s anymore!
This write up was a big help as I just picked up a near mint mirror from a salvage yard for $30.00 with only the mirror harness.
The # 6 yellow wire for reverse light input - has anyone hooked this up? When I replaced my headliner I ran a wire from the dome light to the rear tail lights. Would the # 6 wire work if I tied into the one of the reverse socket wires and if so which wire?
Originally Posted by kingkub57
Just for any of you out there installing this mirror and only have the harness that comes with the mirror, it is a 6 pin connector and you need to use pin #'s 6,4, and 3, #6 is a yellow wire and would be for the reverse light input, # 4 is a violet wire and is used to connect to switched 12 volts, and the # 3 is a black wire and is used for ground. The #'s are inside where the pins come out and are numbered 6.5.4.3.2. and 1 (when looking at the inside of the connector) hope this helps some one in the future. Although I have not done anything for the reverse light, I'm just going to live with it working all the time.
I will say this, this option should of came with all the Xfires it is really a neat addition
And thanks to OCR-XFR for the great write up
