onehundred80
Agree or disagree with what I said you are advocating the use of spacers that are not hub centric.
Why do you think our hubs have such an accurate centring boss?
No, that is incorrect, if this was about spacers, I apologize. Spacers need to be perfectly flat and centered, same with wheels. Wheels with any sort of beveled fastener, cannot be off center, unless the wheel or the hub was drilled that way.
Most spacers do not center on the fastener (mag style can, if made correctly), and typically have oval slots for studs/bolts so they work with many diameter patterns, and different size threads on bolts/studs, there is plenty of slop for them to go off center if they don't center off of the hub.
