americanretrodave
Ok guys, I have a problem not mentioned in this tread; my left headlight is full of moisture but my Roadster is an '06 and the vents pictured in the '04 and '05 models (numbers 1 and 5) are capped, they look sealed. Any suggestions?
How long has this problem been with you? The caps must point down. Someone a good while back said that their leak came from the joint between the lens and the light housing.
There was a photo on here a while ago and it looked lik a goldfish could live in the light quite well.
Take it out, clean it and install the anti-misting kit. While it is out see if there is a leak at the joint, by putting a hose on it.
