Old Feb 15, 2016 | 01:09 PM
pizzaguy
Default Re: ID the oil leak?
Originally Posted by bledrew
Having the valve cover gaskets replaced at the same time. Costly....
Again, waste of money. The vavle cover gaskets are probably not hte issue, it's the seal in the RTV between the breather and valve covers that leaks. While it is nto a bad idea to change the gaskets as well, the real issue is the RTV-type crap they use between breathers and covers.
I am no mechanic, but I did mine myself - have not put them back on cause it is COLD here in North Georgia and my car sits in an unheated stall!
Here is the re-sealed breather-to-valve-cover assembly, again, have not put it back on the car:
I am no mechanic, and can tell you that this was not a hard job at all.
