Old Apr 15, 2016 | 11:22 AM
KDW4Him's Avatar
KDW4Him
Default Re: Crossfire Wont Sart
Originally Posted by hardknocks6936
i did disconnect my battery, matter of fact i bought a new one because my old one was giving up on me. I had to jump start my car the last three times before the check engine went on .....New Battery and it does not start at all or crank.
my car does lock and unlock with the key control....so does that eliminate the skreem? as zip439 mentioned..
Sorry, we need to be very specific here. After you disconnected the battery for 15 minutes and then reconnect did the car start and die three times and then no crank it all?
If you disconnect the battery after the three starts & dies can you repeat the entire process and have the car start/die three times and then no crank at all?
If your answer is yes to both of those scenarios then it is the skreem module or the antenna ring around the ignition. If your answer is no to the above you have multiple issues going on.
Do you have the same symptoms with both key FOB's trying to start the car?
