Old Jul 13, 2016 | 11:56 AM
  #83 (permalink)
bucketlisted's Avatar
bucketlisted
Default Re: Installed Super Bright LED Daytime Running Lights
I can't locate the "little rubber dam with a slit in it for pushing the wire through"
would you have a photo?
thanks
In Canada you must have DRL's come on with the ignition. The method of connection I used was very simple as I did not want to modify or tap into any of the vehicles other lighting circuits to prevent the chance of creating the "bulb out" indicator on the instrument cluster.
I grounded the neg - wire of each LED strip using crimp on ring terminals that I put under some existing bolts on the main lower crossmember behind the front grill. I spliced the two pos+ wires behind the front grill and ran a single wire up the driver side into the fuse box in the engine compartment. When you remove the fuse box cover there is another cover that is held in by tabs on the front and both sides. Once it is removed you will see a couple of main terminal studs right up in the end of the fuse box closest to the firewall. The one in the right corner closest to the fender is live when the key is turned to ON. You can enter the fusebox with your wire on the side closest to the fender as there is a little rubber dam with a slit in it for pushing the wire through. I used an inline fuseholder and crimped on a ring terminal so that it could be added to the stud terminal. Don't drop the nut on the stud terminal into the bottom of the fusebox (I DID) and had a hell of a time fishing it out with a probe magnet.
I used a 2AMP fuse which was the lowest rating I had. These lights draw very little so keep the fuse size low to protect the circuit.
As always, disconnect the neg - terminal on the battery before starting the job.
Also, a little advise when installing the LED Lighting Strips : Make sure the headlight assembly is clean and apply some rubbing alcohol to the area where you will be applying the LED strips. It is best to warm the LED strips up a little before you stick them onto the headlight assembly. I layed mine flat across a forced air heat register in the house and ran the furnace for 15 minutes to make them more plyable for going around the tights corners. I took them out to the garage for installation one at a time when ready to install. Mine stuck really well and have not moved. When installing the LED strips, I was very careful not to touch the adhesive side of the strips and only peeled a little of the paper backing at a time.
I have added some pics of the connection point in the fuse box :
http://i40.tinypic.com/350a39h.jpg View of the stud terminal in the back right corner.You can see my new ring terminal with the blue insulation. This stud is live with the key turned ON.
http://i41.tinypic.com/29w742c.jpg Just another view of same. Black rubber in-line fuse holder can be seen.
http://i44.tinypic.com/zilzip.jpg You can see the black wire enters the fuse box along side the rubber dam.
