Old Sep 1, 2016 | 10:23 PM
pizzaguy
Default re: Franc's OFF ROAD to the Mountain Chalet (Fall Dragon) has been CANCELLED
Putting an address into your GPS for this event will get you lost. If you can't be with us when we leave the lodge, get out your GPS, and put these coordinates into it.
This will take you to a secondary road off US 64 about 8 miles east of Franklin, NC.
If you cant make these coordinates work, then go to "Settings" and change the format to "Degrees Minutes Seconds" which looks like this in the Garmin GPS panel:
h ddd mm' ss.s
Put in:
N 035 05' 58.6 and W 083 32' 59.7 Some GPS's will insist you put in the leading 0's and some won't.
This will take you within 150 feet of the arch above their driveway. Look for the Crossfires in the driveway/field some 250 or more feet past the arch.
Exact position is below, but most GPS's don't do down to .01 seconds of resolution so I left the last digit off my instructions above.
