Old Sep 25, 2016 | 07:58 AM
  #172 (permalink)
pizzaguy
Default Re: Trunk Lid Jammed
That last post tells me the pump runs and the "bow" (the part of the top that contains the rear window) raises - but it does not go any farther. IF I have this right, then:
  • If the pump still runs, but nothing is moving - I'd say you have low fluid (which also means you have a leak somewhere)
  • If the pump quits running when the bow goes up and nothing more happens, I'd guess a travel sensor on one of the cylinders is bad.
