Old Apr 8, 2017 | 06:29 PM
pizzaguy
Default Re: What RPM is best shiftpoint - manual 6 speed
Originally Posted by Ksmi87
which is why I posted that pic- Thanks for the info!
Anyone else here upgrade to LED and it fill their FM radio with static when turned on? Must be the amount of power running to them robbing or causing interference.
LED or HIDs? LEDs should cause no problem, but HIDs are arc lamps, arcing causes spikes on the 12 volt lines feeding the lamps and can be filtered out (the really good kits DO filter well.)
But if the lamps themselves radiate in the EM spectrum well, radio is EM and there is little you can do but find bulbs that are less susceptible to radiating.
