Old Apr 9, 2017 | 02:32 PM
GraphiteGhost
Default Re: What RPM is best shiftpoint - manual 6 speed
I put SRT brakes on my roadster which should help with that,,,,assuming I ever use them....
....Keep those wheels rolling thru the twisties or you will just slide off the road.
Hi Franc, OEM brakes were fine for me, had a blast and did not have much fade. I obviously didn't brake in the turns, not a newb here. Straightaway braking hard, tended to heat the brakes a lot (DUH). I also powered through the curves, actually didn't use the tranny in manual mode, much (auto). Kept up pretty good with the SRT-6's, I thought (and a few others did as well).
