jamesmcaleer
Hi Everyone, I wonder if anyone can help, my 2005 Roadster ( UK model), the roof won`t go down and just beeps when you press the switch, and the spoiler does not work automatically or manually and both happened at the same time, I assume the problem is linked, any ideas would be great, Thanks, Teak
Take all the trip out of the trunk ("Boot"?) and look for water intrusion around the modules in the wheel wells. If you find modules sitting in water, head for a salvadge yard and get new modules and as much of the wiring harness as you can - since the pins in the cable connectors will be corroded badly.
YOu can use my Manual Top Operation video to put the top up and down until you get it fixed.
