Old May 21, 2017 | 11:23 PM
pizzaguy
Default Re: Desperate Help Needed!!!
Originally Posted by SoonerFan
..... he said I was a pound low on freon .... had a small crack in the antifreeze reservoir..... I had to put an entire gallon of antifreeze in it!! Took it back in, needed a new reservoir, Needed a new radiator, Needed a new cooling fan -
So, the car is a pound low on Freon (a system that holds maybe 30 oz at the most anyway)? Where did it all go? I mean, if he has not explained what he did to fix the leak, then don't let him recharge the system until he does.
And the tank is bad - well, that is common and an easy fix.
And the radiator is ALSO bad?
And the fan (motor?) is ALSO bad?
Your 'mechanic' isn't this guy, is he?
