Goldwing
Posting this in the general section, since I do not think it is specific to SRT6s. SRT6 (33k miles) ran fine two nights ago, on a 50 mile round trip. It has been on the road and driven regularly since early May.
Last night it fired right up, then died immediately. I could hear whirring. It did it two more times and then on the fourth attempt, nothing. It did not turn over. Code reader showed no codes. Battery is strong/fairly new. I even tried the second key - nothing.
Searching brings up: 1) ignition issue which appears to be the key not turning at all. It turns fine and all the icons on the display light up normally; 2) RCM module - maybe this is an issue but does it match the above symptoms; 3) Crankshaft Position Sensor - no codes and would this prevent the engine from turning over?; 4) Other??
Appreciate any advice that I could try before I have it towed to the shop. Thanks in advance!
Check underhood fuse #35 just for grins..
