Old Jul 24, 2017 | 10:36 PM
onehundred80
Default Re: Tips required to make a double din face plate
Originally Posted by Speedy4x4
Glad I could help, will see if I can find any more angles.
Keep me posted on your progress.
What are you planning with the hazard light switch?
So, making a tray where cup holder goes that pulls up and is tyhe switch panel?
Would a triangular panel work there also, that rolls, one side smooth and can leave facing up, roll one way and the switches rotate up, the 3rd side is for wiring.
Make any sense to you?
Have a vivid pic in my head and mounting.
The tray as I call it would look like your pics but the whole faceplate would lift out instead of having to remove the whole center console.
The tray flange would be a little thicker than the flange of the little cubby that replaces the cup holder.
The triangular idea has problems with the plug area being quite deep.
