onehundred80
You can buy them on eBay quite cheap, I got one for $45, there are older models of them for other Mercedes and they are cheaper and work the same. Turbomar used one and had no problems, he lists the part number in his post on the subject. Basically the only thing that goes wrong with them are the relays and they can be fix quite cheaply.
If you have problems with a RCM check the fuses, poor soldering and look for burnt out contacts and windings on the relays.
Dave, the one that came in our Crossfires is 170 545 0305.
I have used an older SLK230 module 210 540 0072 and it works just fine.
