Old Aug 12, 2017 | 06:17 AM
CharlieO's Avatar
CharlieO
Default Re: Adhesive for vertical seam on convertible top?
Originally Posted by maggy55
I have the same issue and used the same glue I used for the glass to reinforce the seam, 3M 08609 Window-Weld. It dries flat black so blends pretty well with my black top. Not pretty , but seems to do the job.
I am certain that I will not be using 3M Window Weld for the repair, especially because you have indicated that it is "not pretty." It seems to me that a repair should be possible without any of the adhesive being visible on the outside of the top, and I know that if I use clear Goop I will be able to remove any dried excess with a razor blade.
