Old Aug 17, 2017 | 01:54 PM
alexdc's Avatar
alexdc
Default Re: Swap C32 into E32 (SRT supercharged into NA car)
Originally Posted by Speedy4x4
Srt and na engines are different, srt is built with lower compression to handle the boost, on a na engine might not be able to handle more than 7 psi, boost raises compression.
I'm wondering If the n/a Mt ecu can work with the srt motor. If It can be a drop in kind of swap. Unless the bellhousing of the manual trans doesn't fit.
