Old Aug 18, 2017 | 07:33 PM
onehundred80
Default Re: serpentine belt replacement
Originally Posted by crossfire@srt
I have seen the post on belt removal but do not understand it. Can I simply use a 17mm to relieve the tensioner on the belt? It mentions a torex but what part does it play in releasing the belt tension?
any help will be appreciated
T
Also I am looking to replace the a/c clutch and it has 8 grooves instead of 6 like the regular XF. Any ideas where i can get one. The part # would be invaluable. It would be easier that just replacing the bearing. regular xf bearings and clutches are very easily located but not srt
The SRT6 tensioner does not have the 17 mm hex moulded onto it, you have to use a Torx bit in the screw head. Make sure that it is the largest bit that fits in the sctprew or the Torx socket will be ruinrped and you are screwed.
