It sounds to me like your top did not finish the cycle the last time you put it up, so you have an error when you try to put it down AND the electric lock has not unlocked because, again, the cycle is not finished - the TCM thinks you are not done putting the top up, so it has not commanded the electric lock to let go.
Read this thread, POst 73 in particular. Once you get the trunk open, do the lock mod described so you never to thru this again. You can disable the ELECTRIC lock, the pneumatic lock will still work - the electric lock is only for the 30 seconds the top is moving up or down, you don't need it.
https://www.crossfireforum.org/forum...-jammed-4.html
THEN, you should be able to turn the key on, (I'd start the car) and put the top up and down manually twice, the TCM will watch what you are doing and "Learn" the positions of all the cylinders. THEN, you should be able to hit he button and it should work fine.
