Old Nov 26, 2017 | 12:49 PM
  #57 (permalink)
lovecross's Avatar
lovecross
Default Re: No start/anti theft issue
Originally Posted by shyloe
So I received my new SKREEM module and replaced it, got everything back together and now when I start it the motor churns but it doesn't fire up. This is not at all like a problem I had prior to replacing the skreem module so I feel like the skreem module is working. Does anyone know what my new problem might be?
Congratulations on your skreem replacement!!! (something I hope I never have to do, even w/average+ shade tree experience, lol).
Ditto ala_fire: Crankshaft Position Sensor or Relay Control Module (aka: computer control module). (CAUTION: checking for spark can be SHOCKING; Hi-voltage)
Do Not Despair! Each is a relatively easy & low $ fix! (& so common) Read (& you tube) all you can here on CPS, without going cross-eyed, lol. Hint, you may avoid damage to the connector clip by removing the hold down bolt & CPS before removing the clip. A little masking tape in your socket may help grip & hold the bolt. Install new part & then plug connector on top securely. (Bosch CPS, from Needswings?)
As to the RCM; pm: tighed 1 and send yours to him for complete and low $ repair (including relays & quick turnaround), BTW: I think that guy deserves a medal!!! Needswings Too!!! (email: tighed1@hotmail.com)
Shyloe: you are almost there!!!
