Old Jan 28, 2018 | 04:30 PM
BlazingSaddle's Avatar
BlazingSaddle
Default Re: My Crossfire starts well but dies immediately and repeatedly.
Originally Posted by Steve Jr
Disconnect your battery for 30 seconds , then give it a try. Tell us if you get the same 3 tried then nothing.
I tried that. When I turn the ignition, all I get are clicks. After about 6 tries, I’m only getting two clicks each time I turn the ignition.
To recap, a few weeks ago, my Crossfire would crank and start when I turn the ignition but would die immediately. That pattern would last three times after which the engine would do nothing, including clicks or any sounds. I thought the battery was dead so I got a new battery. With the new battery, I got the same three starts and immediate dying of the engine. I tried two suggestions I read on this forum. 1. Press the lock and unlock button to reset the transponder and start the engine. That did not Change anything. 2. Try starting with my other key. It took two weeks to find the second key. Turned the ignition with it and now I’m only getting clicks. That’s where I am.
Any input is appreciated. Thanks.
Mike
