Old Jan 29, 2018 | 04:21 PM
onehundred80
Default Re: Multi-function Switch/Headlight switch replacement?
Originally Posted by charlestoncrossfire
I will be changing my multi function switch/ turn signal stock in a few days on my 2005 crossfire 6 spd. Did anyone figure out if the Mercedes part has the same plug as the Chrysler part? Thanks.
You can rely on the plug being the same because you will buy a Mercedes switch, do not buy a part using the Chrysler part number or you will pay way to much for it. The Mercedes part number will be on the part, use that number.
It will be the same plug as it will be the same part.
