Old Feb 1, 2018 | 07:18 PM
pizzaguy
Default Re: 2004 Crossfire Electrical Issue
Originally Posted by Romeo212
it will run for 2-3 days fine then just random stall out with no power at all completely dead!
......shows 14.2 when running but if I live it connected and drive for two or three days it will end up dieing out on me.
And not only that the battery’s mess up inside. Since I got a new one from Orielys it has warranty and I’ve changed it to due to bad cells inside like the car messes up the battery too, don’t know why
Has anyone ever told you that you write cryptically? I want to help but it is very hard to understand what you are saying.
Others here are assuming your battery is going dead, and that may be what is going on, but if the car stalls going down the road - then what does it take to get it started back up? Is the battery dead at that point (which would be obvious, but you don't actually SAY that.)
A battery that is boiling it 's fluid out is being overcharged, but if you see 14.2 volts with the engine running, it is not being overcharged.
