Old Feb 10, 2018 | 12:22 PM
amx1397
Default Re: U-joint replaced around $100.00
Originally Posted by Speedy4x4
Oooooooo, you are going to like this
just found this.
how to change the 3 arm flange on trans and rearend to a bolt on yoke, so no need to change to the 4 arm flanges and bolting on flanges, just unbolting the the flanges from output shaft on trans and the flange from the pinion on rearend and install the yokes, then measure out for driveshaft
just started searching for 27 spline yokes to modify and came across this thread, of what he did.
Driveshaft 'yokes' - PeachParts Mercedes ShopForum
I am looking into this if i can do the yokes the driveshaft will cost 300. so if the yokes are less than 100 I going to do it. jim I have a rear and a tranny out of a car that i can use for filament ,,if this works we need NO pilot bushing.
