Old Feb 11, 2018 | 10:43 PM
  #40 (permalink)
BlazingSaddle's Avatar
BlazingSaddle
Default Re: My Crossfire starts well but dies immediately and repeatedly.
Originally Posted by STRANDD
Order one from Needswings.com. You'll give your VIN # and they will program it for you and ship it. In October it was taking about 2 weeks to get in (blame Chrysler). Price was $250.00.
Im stuck. Since it sounded like you’ve done this before, I would appreciate your input. I contacted Rob at Needswings.com who directed to the link below.
https://www.crossfireforum.org/forum...key_fix_v5.pdf
He told me to follow the instructions up to step 9. Then I would be able to open up the lower panel and access the old SKREEM module for replacement. Unfortunately I got stuck at step 6 where I could not locate the #4 screw to take out. See my third photo. Maybe I’m a bit dense but I don’t think I see in my car what the instruction is saying I should see.
Btw, the instruction says by step 9 I should have removed the panel and have the panel removed to expose one half of the transponder ring. That means, at last in my 2008 Crossfire, I should have the panel that contains the headlight switch taken out. See my second photo. That means I need to take out the screws that are holding the headlight switch. The instruction does not mention that at all.
Lastly, step 7 says I only need to take out 2 screws on the panel. See my first photo. Mine shows 4 screws.
I’m lost. Can you please see if you can help me with these apparent discrepancies? Thanks.
