My Crossfire starts well but dies immediately and repeatedly.
Old Jan 11, 2018 | 12:01 AM
BlazingSaddle's Avatar
Default My Crossfire starts well but dies immediately and repeatedly.
My 2008 Crossfire had some oxidation build up in the battery terminals two years ago and had very similar problems. So, naturally, when it started well but repeatedly died immediately, I checked the the battery terminals. There was some build up which I thoroughly cleaned. By that time the battery was dead. I tried jumping it but even after 20 minutes of having the cables attached, the battery remained dead as nails. So I got a new battery and started the Crossfire. Unfortunately, it continued to start and die immediately. Do you folks have any good theories about what the problem may be? Thanks in advance.
Mike
Old Jan 11, 2018 | 10:29 AM
Default Re: My Crossfire starts well but dies immediately and repeatedly.
Describe "start and die immediately". This can be a SKREEM failure, but your symptom description is too vague.
Old Jan 11, 2018 | 05:06 PM
When I start the ignition, the engine immediately cranks up normally but dies just as quickly, even when I pump the gas to try to keep it going. So, it goes, vrooomm.... then immediately, fizzle out.
Old Jan 11, 2018 | 05:11 PM
The question is : Does it do this 3 times, then nothing else ?
Old Jan 11, 2018 | 06:03 PM
Padgett's Avatar
And what are the codes ? (Preferably with a DAS/STAR or Merc scanner). Is the shutdown like a switch or does it sputter a bit ?
Old Jan 11, 2018 | 07:07 PM
Yes, it did it 3 x! Then, no more start, no more cranking, no more nothing. Silence. What does it mean? I just thought the battery only had that much juice left...
Old Jan 11, 2018 | 07:11 PM
No sputter at all... starts up normally then puff... just dies without a fight.. so to speak... I don't know what code since I don't have a scanner.
Old Jan 11, 2018 | 08:09 PM
Steve Jr's Avatar
If you disconnect the battery an retry, do you get the same "3 strikes an not start again". This is a classic SKREEM module going out.
Old Jan 11, 2018 | 10:55 PM
That’s exactly what happened. Got a new battery and after 3 starts, completely dead again, or that’s what it seems like. So I googled it and came back to this forum. If understand this correctly, I’m supposed to purchase a SKREEM module and then use the instruction in the link below.
https://www.moparpartswebstore.com/p...iABEgIgxfD_BwE
https://www.crossfireforum.org/forum...im_initial.pdf
Am I on the right track?
Mike
Old Jan 12, 2018 | 01:04 AM
So, assuming the SKREEM Module has to be replaced, is there a way to program it on your own or is this something that only a dealer can do?
Old Jan 12, 2018 | 01:17 AM
STRANDD's Avatar
Order one from Needswings.com. You'll give your VIN # and they will program it for you and ship it. In October it was taking about 2 weeks to get in (blame Chrysler). Price was $250.00.
Last edited by STRANDD; Jan 12, 2018 at 01:18 AM. Reason: wrote "to you" when it should have been "for you"
Old Jan 12, 2018 | 06:21 AM
And BTW, that $250 is MUCH better than the dealer cost with labor of about $2200.
It is not a difficult DIY, Rob sends the instructions with it. ( even a caveman can do it )
Old Jan 12, 2018 | 03:18 PM
Thank you, Strandd and ala_xfire, for the information. You are correct that 250 is WAY better than 2200. Thanks to Crossfireforum and wonderful contributions by people like you. And love the fact that even a caveman can do it. Lmao.
Old Jan 12, 2018 | 03:40 PM
STRANDD's Avatar
Besides Rob's instructions, there's good info from forum members and you can find the Crossfire repair manual on here. I managed to do it.....and if I can.....you can. Probably the hardest part was taking everything apart and waiting two weeks for the new Skreem to come in. Would have been easier for me to remember where things go working straight through. I would suggest waiting until the new Skreem comes in. Good luck!
Old Jan 13, 2018 | 08:38 AM
RED DOG's Avatar
Just a thought . . . Did you do anything to your key fob recently? Do you have a second key & fob that you can use to try and start the car? If you replaced or disassembled your key fob and missed (re)installing the transponder chip, I think you'll get the same symptoms. Just sayin' . . .
Old Jan 13, 2018 | 01:12 PM
Other than the fact my key fob is old and beaten up, I’ve not done anything with it. I did do a lot of work with garage door openers. Would they share the same spectrum? Just a thought. I will try to dig up my other key, which was never used, and see. My current fob works fine otherwise, I.e. lock and unlock doors.
Old Jan 13, 2018 | 01:14 PM
From what you say, it sounds like Bobs instructions isn’t enough to replace the module. I thought even a caveman can do it
Old Jan 13, 2018 | 01:24 PM
Mrmiata's Avatar
Lock and unlock is not affected by the RFID chip.. starting is.. a couple of people have actually managed to find the chip and get going again after noting "I dropped the fob and it came open"..
Old Jan 14, 2018 | 01:10 AM
STRANDD's Avatar
As a non-natural mechanic....I just find it helps me to see more than one person's version of a repair. Often see/read different minor details that helps me out.
Old Jan 14, 2018 | 09:03 AM
A good idea is to take notes and/or take photos as you go if it is a complicated or a lot of parts are involved. It is always a bit worrisome when after putting everything back together you find a screw or two left over. Taking notes of screw lengths is a good idea, diameters are easy to figure out.
You know you have screwed up big time when your mileage improves due to the weight loss of the parts you had left over.
