Old Mar 4, 2018 | 09:29 AM
  #40 (permalink)
kookus's Avatar
kookus
Default Re: Front Turn Signal Light Bulb Socket
Originally Posted by EpicDesyre
Attachment 32312I have had a problem with mine on the drivers side, one of the contacts got weak and would not hold the connection. It finally broke all the way off and like everyone a replacement is not easy. I will see how long my fix holds. I found a pen with a metal pocket clip that fit in the channel and cut a piece longer than the gap, once I verified the connection with my multimeter and soldered it in place. I built up the bridge with more solder so it made a solid connection in the housing.
thank you for the soldering idea...another awsome fix for me
